hillmate
Message 1 of 4
Hub 4
I would like to get the Hub 4 as had Hub 3 for years, how do I go about it? Or should I just buy one from eBay and change it myself. I am on BT Basic so can't afford to be on high broadband.
3 REPLIES 3
DanielS
Moderator
Moderator
Message 2 of 4
Re: Hub 4
Hi @hillmate,
I can look into this for you to see what options you have.
You will have a private message from me shortly.
DanielS
imjolly
Message 3 of 4
Re: Hub 4
are you having problems with the hh3?  if not why change - if not broke don't fix it
hillmate
Message 4 of 4
Re: Hub 4
Not really got a problem except sometimes the network goes down. But just would like an upgrade to 4. No one has problems with internet, but the companies always shove new upgrades on them. Like Windows going from 7 to 8 etc.
Perhaps it's a woman thing and I like the look of the Hub 4 and want it to match my décor 😅
