Davefbryant
Message 1 of 11
Hub 5 2.4/5 GHz
Hi, just I installed a smart hub 5 and having the same problem. All my smart bulbs and plugs return the only use 2.4ghz error.
Tried turning off the 5ghz but all my devices disconnected as no Internet. Had to turn off the hub to get the Internet back.
How do I disable the 5ghz without losing the Internet signal.
Dave
10 REPLIES 10
VeteranISPUser
Recognised Expert
Message 2 of 11
Hub 5 2.4/5 GHz
Dave
Hi @Davefbryant
Your problem is not the same, you cannot split the bands on the new Smart Hub 2 but you can on the Home Hub 5. The first thing to try is to split the bands 2.4 GHz and 5 GHz
http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
Davefbryant
Message 3 of 11
Re: Hub 5 2.4/5 GHz
Hi John 2,
My apologies, I have the smart hub 2.
As I cannot split the channels, all my smart devices are useless?
May have to go back to the old router.
Dave
VeteranISPUser
Recognised Expert
Message 4 of 11
Re: Hub 5 2.4/5 GHz
@Davefbryantwrote:
Hi John 2,
Dave
Hi @Davefbryant. Have you turned off smart setup?
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
Omallz
Message 5 of 11
Re: Hub 5 2.4/5 GHz
How would that help?
I'm having the same issues, my Sonos Play:1's simply will not connect (they don't support 5ghz)
Davefbryant
Message 6 of 11
Re: Hub 5 2.4/5 GHz
Smart setup was switched on.
Turned it off but still cannot connect to my smart bulbs.
Dave
VeteranISPUser
Recognised Expert
Message 7 of 11
Re: Hub 5 2.4/5 GHz
Dave
Hi @Davefbryant  So next is to try the suggested solution which is turn off 5 GHz connect your devices and then turn on 5 GHz.
Davefbryant
Message 8 of 11
Re: Hub 5 2.4/5 GHz
I tried that, all devices lost connection, even my TV connected via cat lead. Had to switch router off and then restart to regain Internet.
VeteranISPUser
Recognised Expert
Message 9 of 11
Re: Hub 5 2.4/5 GHz
Hi @Davefbryant
Just a thought, you are connected to the SH2 by Ethernet while you switch off the 5 GHz band. Note this will also cut the communications with any Discs as a temporary measure.
Davefbryant
Message 10 of 11
Re: Hub 5 2.4/5 GHz
No by WiFi. Will being connected by cable stop both channels being switched off.
Dave
