Message 1 of 3
Hub 5 passwords
I have misplaced the hub settings card so cannot access the router using new devices. I never changed the default WAP wireless key or the Admin password so it is still on the ones it was set up with. Is there any way I can find the WAP and Admin passwords without the card?
TIA
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: Hub 5 passwords
It should be written on the case of the home hub as well, look at the label.
The card is just for convenience.
Message 3 of 3
Re: Hub 5 passwords
Dime bar! Thanks very much. I'll just slink sheepishly into the corner. Smiley Embarassed
