Brooner82
Message 1 of 6
Hub 6 and WiFi Disc compatibility
Hi, can anyone tell me if a Hub 6 can be connected to a WiFi Disc?
5 REPLIES 5
NeilO
Moderator
Moderator
Message 2 of 6
Re: Hub 6 and WiFi Disc compatibility
Hi @Brooner82 Welcome to the community and thanks for posting, is it a whole home wifi disc or complete wifi disc?
Brooner82
Message 3 of 6
Hi Neil,
I'm not sure, it's a black WiFi Disc if that helps?
VeteranISPUser
Recognised Expert
Message 4 of 6
Hi @Brooner82
It will never work, it is a Complete WiFi Disc. You need a Smart Hub 2 to use a black disc.
NeilO
Moderator
Moderator
Message 5 of 6
@Brooner82 I can confirm that @VeteranISPUser is correct a complete wifi disc won't work with your type of Hub. You'd either need to upgrade to a Smart Hub 2 or consider the whole home wifi discs as they will work with any router.
Brooner82
Message 6 of 6
Thanks, thought that would be the case
