Newbie
Message 1 of 15
Hub / Router hardware update
I have had several package updates since moving to BT in 2015 but none of those updates included a hub / router update. So I am currently 5-6yrs behind the current offering and it’s starting to show in the performance. Can I request a new router update for my Halo 1 package or should I leave when my current package finishes in Feb 2021?
14 REPLIES 14
Message 2 of 15
Re: Hub / Router hardware update
What hub do you have?
As far as I know, there is no way to force a software update but you could try a factory reset if it's not performing well
Message 3 of 15
@Harpo_72
Which BT Home hub do you have at the moment?
Newbie
Message 4 of 15
I think it’s a home hub 4
Message 5 of 15
So you must have a standard ADSL connection and not a superfast one, unless of course you are on superfast, and also have a white Openreach modem.
The Home Hub 4 is the latest home hub for an ADSL connection.
Newbie
Message 6 of 15
How do I confirm that ?
Message 7 of 15
What speed are you supposed to get?
Newbie
Message 8 of 15
63mb>
Message 9 of 15
@Harpo_72 wrote:
63mb>
Then if you have a home hub 4, you must also have a white Openreach modem connected as shown below, as the home hub 4 needs a modem on a VDSL connection. Is that correct?
Newbie
Message 10 of 15
Yes it’s a black box which I thought was the TV stuff
