BSponka
Newbie
Message 1 of 8
Hub drops internet connection when uploading
Hi all,
My BTHub is droping conection if I use OneDrive Sync client. Please can you update firmware on my BT HUB?
Thank you
7 REPLIES 7
Message 2 of 8
Re: Hub drops internet connection when uploading
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Moderator
Moderator
Message 3 of 8
@BSponka Welcome to the community, I'll send you a private message in a few moments with details on how you can contact the moderation team, we'll ask the Hub team to look at this for you.
BSponka
Newbie
Message 4 of 8
Thank you.
Moderator
Moderator
Message 5 of 8
@BSponka thanks for speaking with me this afternoon. I've sent a request to the hub team to get a fix applied to your Hub to prevent this from happening but it will likely be next week before they do this. As soon as I get any updates back from the Hub team I'll post back here.
Moderator
Moderator
Message 6 of 8
Hi @BSponka I'm sorry about the delay replying. The Hub team have asked if you can try a test upload to see if the connection drops out and post back here to let us know if this has reproduced the issue?
BSponka
Newbie
Message 7 of 8
Hi all,
I can confirm that after BT carried out a firmware update on my router issues has been resolved!!!
When uploading/synchronizing large files - connection is now stable.
Thank you for your support.
Moderator
Moderator
Message 8 of 8
Hi @BSponka Thanks for checking that and posting back and I'll let @NeilO know the problem is resolved.
Cheers
John
