BSponka
Message 1 of 8
Hub drops internet connection when uploading
Hi all,
My BTHub is droping conection if I use OneDrive Sync client. Please can you update firmware on my BT HUB?
Thank you
7 REPLIES 7
Keith_Beddoe
Message 2 of 8
Re: Hub drops internet connection when uploading
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
NeilO
Moderator
Moderator
Message 3 of 8
@BSponka Welcome to the community, I'll send you a private message in a few moments with details on how you can contact the moderation team, we'll ask the Hub team to look at this for you.
BSponka
Message 4 of 8
Thank you.
NeilO
Moderator
Moderator
Message 5 of 8
@BSponka thanks for speaking with me this afternoon. I've sent a request to the hub team to get a fix applied to your Hub to prevent this from happening but it will likely be next week before they do this. As soon as I get any updates back from the Hub team I'll post back here.
NeilO
Moderator
Moderator
Message 6 of 8
Hi @BSponka I'm sorry about the delay replying. The Hub team have asked if you can try a test upload to see if the connection drops out and post back here to let us know if this has reproduced the issue?
BSponka
Message 7 of 8
Hi all,
I can confirm that after BT carried out a firmware update on my router issues has been resolved!!!
When uploading/synchronizing large files - connection is now stable.
Thank you for your support.
JohnC2
Moderator
Moderator
Message 8 of 8
Hi @BSponka Thanks for checking that and posting back and I'll let @NeilO know the problem is resolved.
Cheers
John
