Message 1 of 2
Hub needs repeated restarts
Hi
Whenever there is an issue with my broadband or the hubs power is interrupted it takes multiple restarts probably about 7/8 over about two hours to get it to work again. It does this even when it’s a problem in my house such as moving the plug socket or then the power is switched on and off at the fuseboard so it’s not just an issue on the network.
Sometimes it flashes pink, sometimes flashing orange , sometimes it’s audibly clicking.
Even when I leave it over night it still doesn’t connect without having to reboot again.
Surely this isn’t right ?
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: Hub needs repeated restarts
Are you able to temporarily run an extension lead to another mains socket to rule out a poor internal connection?
