zacepi
Message 1 of 9
Hub6 firmware update - broadband now dropping SG4B1000E077
Dear all,
I am also trying to contact BT support to address this problem.
My BT Hub6 did a firmware update (itself) on March 9th. Since that date it has been troublesome - dropping broadband and rebooting several times per day. Prior to the upgrade it has been rock solid for 2 years.
What I would like to know is - is there anyone else now on this version who has experienced similar issues?
My plan is to swap in another router as well as escalate with BT - several posts on this community show that response from BT can be...patchy.
Redacted Tech log below
Thanks!
Product name:
BT Hub 6A
Serial number:
+084319+NQ*********
Firmware version:
SG4B1000E077
Firmware updated:
09-Mar-2022
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 0 Hours 44 Minutes 22 Seconds
Data rate:
20.00 Mbps / 77.65 Mbps
Maximum data rate:
22241 / 79045
Noise margin:
7 dB / 4.2 dB
Line attenuation:
28.4 dB
Signal attenuation:
18.2 dB / 28.4 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
160 MB Uploaded / 266 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
nope
2.4 GHz wireless channel:
Channel 1
5 GHz wireless network name:
nope
5 GHz wireless channel:
Channel 48
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
58:90:ZZ:D5:9A:ZZ
Software variant:
Boot loader:
7.33.1
8 REPLIES 8
zacepi
Message 2 of 9
Re: Hub6 firmware update - broadband now dropping SG4B1000E077
Anyone?
PaddyB
Moderator
Moderator
Message 3 of 9
Hi @zacepi,
Thank you for posting. I'm sorry if you're having problems with the stability of your connection. To make sure there isn't a line fault when you use your phone do you get any noise on the line?
Please can you run a quiet line test by dialing 17070 from your BT Landline. If using a corded phone then the test should be quiet, if you are using a cordless phone then you may hear a low hum.
If the line is completely silent I would try a factory reset of your hub.
How do I reset my BT Hub to its factory settings
Thanks,
Paddy
zacepi
Message 4 of 9
Thanks that's useful.
The line was pretty quiet. I have now put an old modem/router on and am monitoring
licquorice
Message 5 of 9
It shouldn't be 'pretty quiet', it should be totally silent.
agc247
Message 6 of 9
I am having exactly the same issue - broadband connection is dropping a couple of times a day since the new firmware update. Previously rock solid.
zacepi
Message 7 of 9
I put that down to my cordless landline phones (Gigaset)
zacepi
Message 8 of 9
This is what I wanted (well, sort of) to hear. I'm a firm believer in
"Something has stopped working"
"What changed?"
"ABC"
"Well, it's extremely likely that ABC has caused it to stop working"
In our case, ABC is the firmware.
I would suggest you temporarily swap your HH6 if you can. I found my old HH5 and put that on as a test. So far it's been good
zacepi
Message 9 of 9
A follow up.
The older HH5 I swapped in has been rock solid and not dropped the DSL. So I conclude that the firmware update has screwed up the HH6. Trying to get BT to accept this may be a journey...
I don't particularly want to put the HH6 back on again as it's interfering with my work. I'll try my luck with support
