Message 1 of 4
Humax DTRT2100 problem
This has just started. When I put the box into standby, after a few minutes the light changes from purple to red and I need to restart and it goes through the "waking up" etc etc.
how is this rectified?
3 REPLIES 3
Message 2 of 4
Re: Humax DTRT2100 problem
Sounds like the power management settings.
The box has a smart mode, it learns when you switch it off at night and goes into deep hibernation shortly after (the red light) but it should also learn when to come out of deep hibernation in the morning so that when you get up the light is purple
Message 3 of 4
Solved the problem. Changed the power option to smart mode .
Don't know how smart got turned off but its ok now.
Message 4 of 4
oops ........ forgot to say thanks Les.
