Message 1 of 3
Hybrid Connect sim card
Hi can the sim from this unit be used on a  different LTE router ,eg Microtik
2 REPLIES 2
Message 2 of 3
Re: Hybrid Connect sim card
No, the sim is only activated when the Smart Hub 2 detects no signal on your fixed line, it then communicates with the Hybrid Connect for that to be the source of internet for the Smart Hub 2, it's not designed to work with 3rd party equipment.
Message 3 of 3
Thanks for the prompt reply ,i didnt think my customer would be able to use the sim
