Message 1 of 2
Hybrid Connect - working away from home
I sometimes have to work away from home for a week or so.  The internet connection at the hotels/caravan parks ranges from quite appalling to non-existent.   Is it a breach of terms and conditions if I take the hybrid-connect with me to use while I'm away from home?
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Hybrid Connect - working away from home
Hi, @cup welcome back to the community and thanks for posting, I'm sorry about the delay replying.
Yes, that would be a breach of the terms and conditions.
28.  The Hybrid Connect is designed to be used only when your fixed BT Fibre broadband connection is unavailable. If you are using it in a way different to its intended use, we reserve the right to take action which may restrict your service.
Neil
