Message 1 of 8
Hybrid connect setup fails at signal test
Hi guys.
Im having a right mare with this Hybrid connect.
Im trying to set it up using the app but it just wont work.
I go through the whole process I have it connected to my smart hub via ethernet I have 3 bars on the 4g signal & the middle light turns solid blue all good so far until I continue & it gets to signal test it counts down from 10 but at 8 I get this every time.
I just cannot get past this so as it says im contacting someone for help.
Thanks in advance.
7 REPLIES 7
Message 2 of 8
Re: Hybrid connect setup fails at signal test
While you're waiting for expert help, here are a couple of BT videos to help set-up your Hyrbid Connect.
https://www.youtube.com/watch?v=YUVubo63uOU
and
https://www.youtube.com/watch?v=Glyn07HodTQ&t=9s
Message 3 of 8
Hi @InTheBox have you tried placing it close to a window?
Neil
Message 4 of 8
Hi @NeilO
Yep its located in a window now about 3 feet away from the hub.
I was told by BT to work best it has to be connected to tje hub via ethernet but I have tried both ways I just can't get past the testing signal part of setup
Message 5 of 8
Thanks for replying by tje way
Message 6 of 8
Hi @Carlusha.
Cheers for those i have watched them & tried setting it up as instructed in those videos
Message 7 of 8
@InTheBox Thanks for confirming that, unfortunately, I can't provide any further guidance than what's already been recommended in the help videos, sorry.
Hybrid Connect problems are being looked after by a specialist team at the moment, if you call 0800 800 150 and ask to report a fault they'll get you through to someone who'll be able to assist.
Neil
Message 8 of 8
Ok @NeilO
That is for that I'll give them a ring on Tuesday I've wasted enough of my Easter weekend on this 👍
