It is a BT Dual Band WIFI Extender 610. It had been connected to my previous hub. I have tried to connect by ethernet cable, I have also tried by resetting the extender but have had no success.
It is a BT Dual Band WIFI Extender 610, I had been connected to my previous hub. I have tried to connect with an ethernet cable, I have also tried by resetting the extender but without success.
It is possible but it's not recommended.
Presumably BT have also supplied you with a black disc, you can request a maximum of another two and they're a far better solution than a wi-fi extender
Halo comes with a Smarthub2 and one Complete Wi-Fi disc, you can have a maximum of 3 discs at no extra cost
I just did it. WPS did not seem to work so I followed the instructions to do the connection via the web interface. After the procedure had completed there was no sign of the extender. The hub management page said it was connected!. I kept doing a factory reset and trying again. Although I live in a four bedroomed house the extender was always too close wherever I put it. The breakthrough came when I ran an extension cable out to the front gate and test the signal strength on an app on my phone. It was 99% in the house but dropped to 34% by the front gate and switched to the 2.4 GHz band. I plugged the extender into the extension reel and let it boot. Result 99% on 5GHZ. The extender no longer behaves as per the instuctions - there are no names with ext in front. It simply broadcasts the same SSID as the hub but your device should automatically switch seamlessly to the signal from the extender if its signal is stronger than that from the hub. Hope this helps others
