XETOG
Newbie
Message 1 of 2
I have just bought an AV600 broadband extender.
I have just bought an AV600 broadband extender to carry the internet signal to a TV at the other end of the room 15' away (same circuit).  I have tested the speed onto the first plug-in extender as just over 30mbs.  At the other end I can get only just under 6mbs out of the device, which is too little for smooth playback of catch up serviced (BBC iplayer etc).  I have tried the receiver end in the kitchen and can get less than 1mbs in there.  The house is modern, so the wiring is OK, although the kitchen is on a separate circuit which may account for that problem.  Any idea why the loss of broadband speed should be so great?
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: I have just bought an AV600 broadband extender.
What is the make/model and manufacturer of the adaptors.?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
