ipanda
Message 1 of 2
IPv6 Options Disabled on HH4
Hi,
After changing to the BT HH4 due to some internal network changes (see previous post about issues with BT TV setup) I have come across an issue with IPv6 not being available on my BT HH4. Please see the following screenshot:
I have been on the phone with BT Support for 1-2 hours and they were unable to help me - we tried a factory reset of the HH4 and checking multiple settings but they said they couldn't provide any support.
I had previously had IPv6 working on the previous OpnSense install but I am unable to use that due to the aforementioned BT TV issues.
I require IPv6 for work as some servers I work on are only available over IPv6.
If anyone could provide any guidance on this issue, that would be great.
Regards,
Ben
1 REPLY 1
busterboy1
Expert
Message 2 of 2
Re: IPv6 Options Disabled on HH4
Seems the Home Hub 4 doesn't support it @ipanda
Mine is exactly the same greyed out.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
