Novice18_66
Message 1 of 8
'Int.' displayed above 'Mute' button on landline cordless phone (with answering machine).
'Int.' displayed above 'Mute' button on BT XD56 cordless phone (with answering machine). What does this mean?
7 REPLIES 7
Novice18_66
Message 2 of 8
icon on display window
'Int.' is displayed above 'Mute' button on BT XD56 cordless phone (with answering machine). What does this mean?
licquorice
Message 3 of 8
Re: icon on display window
Internal.
Please don't make multiple posts for the same topic.
Rachels
Message 4 of 8
What does internal mean - why is it there and what does it do?
Having problems with phone so trying to eliminate anything that could be the issue
Iangla
Message 5 of 8
I think if you press it then it will make the phone ring, in case its fallen down the back of the sofa and you can't find it.
Rachels
Message 6 of 8
Thanks but I don’t understand.
It isn’t really a button as it is on the screen part just above mute button and you couldn’t press it if the phone has fallen down the sofa. There isn’t an int button on the base unit either
Iangla
Message 7 of 8
I had a look for the user guide, you can find it here.  http://btsupport.custhelp.com/ci/fattach/get/5111177/1506349842/redirect/1/session/L2F2LzEvdGltZS8xN...
As far as I can see I think its for a feature that allows you to make calls between handsets
NeilO
Moderator
Moderator
Message 8 of 8
@Rachels what problems are you having with the phone? Sometimes resetting the handset and base can resolve issues, page 46 on the userguide that @Iangla  posted shows you how to do that.
