Edubzboy
Message 1 of 7
Internet Extender cutting out
Hello, I have a bt WiFi extender 300 which I use mostly for gaming, for the last few months it cuts out every few hours and is very frustrating when I am playing online and also annoying for my phone , does anyone know a fix for this? Thanks!
6 REPLIES 6
Message 2 of 7
Re: Internet Extender cutting out
Are you sure it is only the extender that is cutting out or is your Internet connection/ wireless connection  that is actually dropping out?
Edubzboy
Message 3 of 7
Yeah I’m pretty sure it’s just my extender as I get the message on my console ‘lan cable not connected’ and then I see the extender is flashing to reconnect
Message 4 of 7
Are you connecting to it via wireless or are you using an Ethernet cable?
Have you tried a factory reset of the extender?
Edubzboy
Message 5 of 7
Wired, how do I factory reset?
Edubzboy
Message 6 of 7
Also, I have now discovered that it is a WiFi extender 610
Message 7 of 7
