piperd
Message 1 of 2
Issue connecting my Amcrest ProHD 1080P WiFi Camera IP2M-841B
Hello,
I've recently upgraded to Halo 2 with the latest Smart Hub 2, the issue I'm having is reconnecting my Amcrest ProHD Camera (Model No. IP2M-841B). I've tried getting it connected via the Amcrest View Pro App on my android phone both wirelessly and also as recommended via an ethernet cable. This camera only works on the 2.4GHz frequency band, not 5GHz. It worked fine on my previous Smart Hub. Is the only solution to go back to my old hub or upgrade the camera to the latest dual-band version?
Any advice would be most appreciated.
1 REPLY 1
piperd
Message 2 of 2
Re: Issue connecting my Amcrest ProHD 1080P WiFi Camera IP2M-841B
After following suggestions from an Amcrest Technical Advisor, I can confirm that I have now got my camera working on the Smart Hub 2.
