Trev11
Message 1 of 4
Landline phone display
Hi I have a Bt landline phone model number BT3110 and it’s always flashing to show I have missed calls and I can’t find out how to stop it flashing I’ve tried menu but obviously I’m not doing it right so any help would be appreciated
3 REPLIES 3
RobbieMac
Moderator
Moderator
Message 2 of 4
Re: Landline phone display
Hi @Trev11
Thanks for your post and welcome back!
I'm sorry for the problems you're having with the handset.  Have you had a look through the user manual?  You can download the manual here if you don't have it to hand -> BT3110 Nuisance Call Blocker
You'll also find the number for product support on the link above if you're still having problems.
All the best,
Robbie
Trev11
Message 3 of 4
Thank you done that and it helped and now I have sorted it and no longer flashing and I now know for future flashes 😊
RobbieMac
Moderator
Moderator
Message 4 of 4
Nice one @Trev11
Really glad to see you got this sorted out.
All the best,
Robbie
