bueller
Message 1 of 4
Lenovo Laptop will not connect to BT whole home
Hi
We’ve had bt whole home for a few days,it’s working well, every device we have connects fine to the Wi-fi apart from one - a Lenovo laptop - anyone know if this is a known issue please? Hopefully there is a fix .
Tags (2)
dgw1
Message 2 of 4
Re: Lenovo Laptop will not connect to BT whole home
Try configuring your WLAN card to use wireless mode b/g only.
bueller
Message 3 of 4
We are having the same problem - do we change the WLAN card on the laptop or on the router? Many thanks
BT Devices Expert
BT Devices Expert
Message 4 of 4
@bueller
Have you updated to the latest firmware (v1.02.03build03)?
We found an issue with Intel Centrino chipsets caused by an Intel driver update. There is a fix in the latest WHW firmware.
BT Device ExpertDan O
Show your appreciation!
Click on the thumbs up next to a reply to say thanks
Kudos”
I am a BT Employee and an expert on BT Devices queries. I am here volunteering my own time to give advice, and help where I can with BT device queries. Go here for more info.
