Message 1 of 7
Lightning strike kills router
Hi, We have just had a lightning strike and my router has totally died.  No lights, nothing.  Tried resetting but nothing.  Do I need a new router?  My landlines is working fine.
6 REPLIES 6
Keith_Beddoe
Message 2 of 7
Re: Lightning strike kills router
@davidandrewwalter
Welcome to this user forum.
Which BT Home hub do you have, as some are more susceptible to damage?
Jeremy69a
Message 3 of 7
That happened to us and yes a new router was needed.
Message 4 of 7
Message 5 of 7
Hi, I have the Smart Hub 2 which has effectively blown and should get the replacement Smart Hub 2 tomorrow.  I will need to link it to my Whole Home Wi-Fi mesh (Dual-band AC2600).
I know I need to connect my new router to a disc via an ethernet cable but can anyone point me in the direction of a step by step guide to setting up the new router with the Whole Home Wi-Fi mesh system?
Keith_Beddoe
Message 6 of 7
@davidandrewwalter
There should be no difference, as the Whole Home system (white disks)  runs independently of the router.
Message 7 of 7
Thanks Keith. If I run into any problems I will come back.
