Message 1 of 4
Lost wifi extender password
Have just moved BT wifi extender 750 and can't find the password for it so can't log in to make the most of it.  Is there any way to retrieve / reset the password ?
Thanks for any help !
3 REPLIES 3
Message 2 of 4
Re: Lost wifi extender password
According to the instructions the password should be on the back of the guide that came with the extender.
See link for Instructions
http://btsupport.custhelp.com/ci/fattach/get/4709679/1457012687/redirect/1/session/L2F2LzEvdGltZS8xN...
Message 3 of 4
Unfortunately I can't find the guide
Message 4 of 4
Have you checked the extender to see if the default password is on any label that is on the extender. If it is not you could try a factory reset of the extender which might allow you into the settings. If it asks for a password you could try using "Admin" which is often the default setting for some devices.
