BT Devices Expert
BT Devices Expert
Message 11 of 15
Re: Low-voltage extension?
The WHW DC jack is 5.5mm external and 3mm pin diameter with output 12V 1.5A if you wish to extend it.
shaunmpond
Message 12 of 15
brill - off to search well-known websites 😉 Thanks!
shaunmpond
Message 13 of 15
hmm... plenty of 5.5mm and 2.5mm but nothing for 5.5 and 3 😞
BT Devices Expert
BT Devices Expert
Message 14 of 15
Which PSU do you have with your Whole Home discs?
We recently changed the PSU to be the same as the Home Hub 6A (but white). This has a longer cord length.
shaunmpond
Message 15 of 15
it says MU24-Y120150-82 I think! 🙂  The lead is fairly long, it's just for this one disk that I want to put up high (because the only other place is about 40cm form the ground, not ideal!
