shaunmpond
Message 1 of 15
Low-voltage extension?
I've searched the board and there doesn't seem to have been a good answer yet: do we know what the specification of the plug that goes into the back of the Whole Home WiFi disk? I want to place my "base" disk, that's connected to the router, high up on the wall, to improve connectivity to other disks that are lower down (the house is built on a hill, so there's no line-of-sight otherwise). A mains extension isn't suitable, since that's leave the transformer dangling half-way down a wall! I'm looking to put the low-voltage cable and ethernet in trunking, then paint over, so that they're hidden.
Any ideas? Is it this size - 2 Pin DC/DC Power Socket Jack Extension Cable Extension 2 m 5.5mm/2.1mm - **Edited**
14 REPLIES 14
Message 2 of 15
Re: Low-voltage extension?
you need to remove the link to amazon as not permitted on forum
shaunmpond
Message 3 of 15
I got a PM to tell me that thanks 🙂 I'ts done
Message 4 of 15
You could always just cut the low voltage lead and lengthen it by joining in an extra length of cable, that way the plug size doesn't matter.
shaunmpond
Message 5 of 15
I thought about that, but I need to keep everything as neat as poss, as it will be on "display"... 😞
Message 6 of 15
Ah, thought it might be hidden in conduit/trunking.
BT Devices Expert
BT Devices Expert
Message 7 of 15
Hi @shaunmpond
How long do you need it to be?
shaunmpond
Message 8 of 15
! only need to add about 1 Metre...
Distinguished Guru
Message 9 of 15
I have extended the power cable on my cctv camera using an extension cable, plenty of them on that well known auction site. Just search on the plug size mine was a 2.5mm
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
shaunmpond
Message 10 of 15
I have extension cables for my CCTV camera, but they're not the same size as the BT Whole Home hub... 😞
