ThinkPadUser
Message 1 of 2
Maximum nodes for BT Mini Connector?
I was wondering what are the maximum BT Mini Connectors (nodes) that I can have in a network.
1 REPLY 1
Dan-O
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: Maximum nodes for BT Mini Connector?
Hi,
Logically you can have 16 in a single paired network but the performance will be significantly degraded.
I would recommend no more than 8 to maintain good performance but this will vary depending on usage and simultaneously transferring data on several Powerlines.
Dan-O
