Gerry55
Message 1 of 18
Mini Conector problem
Hi everyone
I am a new BT customer I have a annoying problem.
I have connected my 1st tv to my router and freeview box and everything workes fine,
I have connected my 2nd tv in to my 2nd freeview box and a mini conector (which has a costant blue light) but I get the on screen message "Broadband conection unavailable" Ive done all the usual things turn everything off, reboot router re-pair connectors etc. I'm sure its something simple I'm missing
Any help would be greatfully appreciated
Thankyou
17 REPLIES 17
Message 2 of 18
Re: Mini Conector problem
Does the second TV work if you disconnect the first freeview box from the router?
Gerry55
Message 3 of 18
No the second TV work if I disconnect the first freeview box from the router?
Message 4 of 18
If you swap the freeview boxes which TV works?
Message 5 of 18
Which FreeView boxes are you using are they just Smart TVS?
Gerry55
Message 6 of 18
Bt freeview.jpegThe small freeview box in the picture
Gerry55
Message 7 of 18
Good idea will check it out
Message 8 of 18
So they are BT YouView boxes.
Have you subscribed to BT multiroom? If not, only one box will work at a time.
Gerry55
Message 9 of 18
Ah......... No I have not subscribed to multi room I'm a recent Ex Virgin customer so this is all new to me how does thst work?
Message 10 of 18
See http://bt.custhelp.com/app/answers/detail/a_id/48891/~/can-i-watch-bt-tv-in-more-than-one-room%3F
Without it, you should still be able to watch FreeView channels delivered down your TV aerial, but not subscription channels delivered using multicast over the Internet.
