Message 1 of 4
Mini Whole Home Wi-Fi Ethernet Backhaul on multiple discs
Hi all, I have a 3 disk pack of Mini Whole Home Wi-Fi.
The system seems to be running OK when one disc is connected to the router however when I connect further discs to the router the network becomes unstable.
  • The app becomes unresponsive
  • Handoff between discs doesn't happen
  • Network becomes very slow
  • Devices are dropped off wifi and can't log back on (Network unavailable or password issues)
Has anyone got any experience of this and tips on getting this to work?
Thanks, RobJ.
3 REPLIES 3
Message 2 of 4
Re: Mini Whole Home Wi-Fi Ethernet Backhaul on multiple discs
Hi @RobJ2  welcome to the community and thanks for posting, I'm sorry to see you're experiencing issues with the Min Whole home wifi discs when connecting via them via ethernet. I'd recommend resetting all the discs using the pin hole reset button on the back to see if that helps.
If you need further assistance please get in touch with us.
By phone: 0808 100 6116
Monday to Friday 9.00am to 5.30pm
Saturday 9.00am to 2.00pm
By email: btconnectedhome@bt.com
Neil
Message 3 of 4
Thanks Neil,
I'll give the reset a try and go from there.
Cheers, RobJ.
Message 4 of 4
@RobJ2 No problem at all, if you could keep the thread updated with your progress it would be greatly appreciated.
Cheers
Neil
