northshields
Message 1 of 6
Mini Wi-Fi Home Hotspot 500 Multi Kit
I have had the above kit for two years and, for the most part, it has worked well.
However, every so often - perhaps once a week or so on average - one or other of the hotspots (but not both at the same time) will lose its internet connection even though all the lights are showing steady green. Sometimes it corrects itself after a short while, but sometimes it is neccessary to disconnect and re-connect that hotspot.
Does anyone know of any reason for this and whether there is a cure, or are the hotspots faulty, or is it "just one of those things"?
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: Mini Wi-Fi Home Hotspot 500 Multi Kit
Hi @northshields and thanks for posting.
This does sound like 'one of those things' but you might want to try the product support guys who will be able to confirm. You'll get the contact details at Mini Wi-Fi Home Hotspot 500.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Oxlade1
Message 3 of 6
There is a firmware update available that improves this problem, see: http://bt.custhelp.com/app/answers/detail/a_id/51972/
You can access the Hotspot interface by browsing to http://mybtdevice.home
Moderator
Moderator
Message 4 of 6
Thanks for that @Oxlade1.
@northshields, have you tried updating the firmware?
Cheers
David
Kudos”
northshields
Message 5 of 6
Oxlade1,
Thank you very much for that pointer. The firmware was, indeed, out of date, so I have now dealt with that and am keeping my fingers crossed.
The update was not entirely painless, but we got there in the end after a certain amount of switching off and back on again. It was only then that I realised that the update had changed the SSID and password back to the original, and so that had to be dealt with as well.
Anyway, many thanks for your help.
Moderator
Moderator
Message 6 of 6
Thanks for confirming that @northshields and many thanks to @Oxlade1 for helping out.
Cheers
David
Kudos”
