Emma77
Message 1 of 11
Mini hub
My mini hub wouldn't connect today and now it won't switch on. I have tried resets etc. Should I get a replacement or is there anything else I need to do?
10 REPLIES 10
imjolly
Message 2 of 11
Re: Mini hub
did you get hub because you had lost internet connection
Emma77
Message 3 of 11
Re: Mini hub
Yes. There was problems with my broadband & because i am a keyworker i was sent the mini hub for a month to keep me going
imjolly
Message 4 of 11
Re: Mini hub
Is your connection now working as it appears the mini hub has been turned off
Emma77
Message 5 of 11
Re: Mini hub
No the hub won't switch on. No lights when i push the power button.
Keith_Beddoe
Message 6 of 11
Re: Mini hub
Is it fully charged?
Emma77
Message 7 of 11
Re: Mini hub
It had plenty of charge but i will leave it plugged in to see if that makes a difference
Keith_Beddoe
Message 8 of 11
Re: Mini hub
See this page https://www.bt.com/help/bt-halo/fix-a-problem/fix-problems-with-your-4g-mini-hub-for-bt-halo-custome...
Try the reset button or hold the power button down for ten seconds.
Emma77
Message 9 of 11
Re: Mini hub
Yip i have already done this a number of times but no life
Keith_Beddoe
Message 10 of 11
Re: Mini hub
The only option left is to call BT and hopefully they will send you a replacement, as it could be a faulty battery.
