jdmyers333
Message 1 of 8
Minihub
Hi i have just been sent a minihub from BT which is now redundant since the fault has been fixed. Can i make use of the minihub at my caravan.
7 REPLIES 7
-Richie-
Guru
Message 2 of 8
Re: Minihub
It will be switched off when the fault closes down, reactivated again if you have another fault in the future.
jdmyers333
Message 3 of 8
Re: Minihub
Not really what I was asking, I know they can switch it on off.  What I'm asking is can it be used as a mobile internet when I'm at my caravan. Like a mobile hotspot. I'm with EE
jdmyers333
Message 4 of 8
Re: Minihub
Not much help here then!
Anonymous
Not applicable
Message 5 of 8
Re: Minihub
The 4G hub is supplied as a short term loan whilst there is a fault on your broadband, it is not supplied long term and as @-Richie- has already said, it wll be switched off anyway. So if you really need it spelling out, then the answer to your question is No
jdmyers333
Message 6 of 8
Re: Minihub
Dont get so high and mighty, that was a legit question that didnt get an answer.
Message 7 of 8
Re: Minihub
Not sure what you were expecting when you made a facetious comment 3 hours after your original post!
People on here who help are nearly all unpaid volunteers and just BT customers like you.
NeilO
Moderator
Moderator
Message 8 of 8
Re: Minihub
Hi Everyone, Please keep it friendly, we want all community members to feel comfortable when asking and answering questions. Thanks
