will_1978
Message 1 of 3
Mixing Wifi Discs
Hi, can I mix different wifi disks? For example can I have a the Premium Whole Home Wifi triple pack downstairs (where I have significantly more wireless devices as well as the need to have more ethernet ports) and can I then have 3 standard discs on my upper 2 floors?
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: Mixing Wifi Discs
lnajr02
Recognised Expert
Message 3 of 3
Hi, you can't mix Whole Home discs types sorry , you can only add the same type, i.e. if you have premium discs then you can have up to 6 premium discs on the one App / network. You can add an Ethernet switch to the Ethernet port of the discs to give you more ports if you are only looking to increase the ports. Good luck
