glennscott
Message 1 of 24
More than 6 Bt Wholehome Disc's
Hi,
Has anyone found a way to add a 7th dish to the BT Wholehome system? I have 6 connected and working perfectly.
In the BT app the "add disk" is greyed out. I suspect the system only supports 6, but I have been unable to confirm this, I would really like to add one more unit.
Thanks!
Tags (1)
23 REPLIES 23
BrunoN
BT Devices Expert
BT Devices Expert
Message 2 of 24
Re: More than 6 Bt Wholehome Disc's
Hi, 6 discs is indeed the maximum.
Castleclough
Message 3 of 24
Can I ask why is it only limited to 6? The whole point of mesh networking is that you can daisy chain and this extend the network. I have a large house with stone walls and it seems I have just wasted ££’s of investing in a BT WholeHome network
mcbro
Message 4 of 24
I would also like to add a 7th disc to reach my garage and am puzzled as to why this is not possible
mcbro
Message 5 of 24
So I succumbed to Black Friday and got a further 2 discs, knowing that I could only add 1 to my existing 5 disc set up based on the above. If nothing else I thought I could upgrade my father-in-law-law’s set-up with my spare disc. The 6th one added seamlessly via the usual plug in to router and wait for the update and the solid blue light after 5 mins. And then I thought, why not, let’s see if I can get the solid blue on them 7th disc. Plugged it into the router and waited as usual, purple, flashing blue, solid blue, purple, flashing blue, solid blue. And solid blue remained.
I relocated the disc and lo and behold I have a 7 disk set up. Not sure how to describe the topology but disc 7 has attached itself to another disc and not to the primary disc that’s attached to the router. But I’m well chuffed as I’ve now got WiFi in my garage 😃
BrunoN
BT Devices Expert
BT Devices Expert
Message 6 of 24
Hi @mcbro. Great stuff. Good to see it's working for you.
For others who may be tempted to try this, please note that maximum supported is still 6 discs.
Anything more than that and we can't guarantee that the system can remain stable.
Also, the App will not display the 7th disc and you may see some strange behaviour.
But good to see people experimenting 🙂
jswanston
Message 7 of 24
I would also like to have more 6 disks. I live in an old house and need a disc for each room due to the thick stone walls. one for the garage and also one for the garden would be great!
mcbro
Message 8 of 24
Hi jswanton
I've had a bit of a move around of my disks now and have managed to get one into my garden some distance from the nearest one in my house. I’ve installed CCTV which whilst wireless, wouldn’t reach my gates where I wanted to install a camera. So I’ve managed to get a disk by the gates and installed it in an IP66 rated box and then fed an Ethernet cable to the camera. It works perfectly, plus the added bonus of WiFi down the garden !
The disk is only showing as a “poor” signal at 2.4 MHz but it is stable. I did find that I needed to install one of my disks in the window as the WiFi signal to the gates disk gets through glass easier than brick.
Hope you have success with your set-up.
pdacolin
Message 9 of 24
I have 7 discs in my whole home mini setup and the 7th disc shows in the app 😁
lnajr02
Recognised Expert
Message 10 of 24
The App for Whole Home Gen 1 only supports 6 discs currently, if you add more than 8 using the GUI they are unstable.
BT are developing this all the time so improvements are being developed all the time.
