Message 1 of 1
Multiple BT Whole Home systems on the same LAN
Can I have two different BT Whole Home mesh systems each with its own name on the same LAN?
The LAN is made up of two ethernet switches connected by a wireless bridge.  The two switches are therefore in the same broadcast domain and currently all connected wired and WiFi devices are in the same subnet.  The Whole Home discs are in two groups of three with distinct names for the two meshes.  Each Whole Home mesh has its own master disc with an ethernet cable to its own local switch and the meshes are in different buildings and probably unable to 'see' the WiFi signals of the other mesh although I can't be certain about that.
