HighWire
Newbie
Message 1 of 2
My BT6590 digital cordless phone
My phone suddenly made a piercing sreeching noise and I was forced to unplug it. I have since replugged it and it is fine. What caused it?
1 REPLY 1
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: My BT6590 digital cordless phone
If your phone is accidentally left "off the hook" for too long then the BT line automatically plays this loud noise so people notice and put phone back on-hook.
If the noise came from the earpiece then its most likely what happened.
If it keeps happening when you know for sure that you closed the line since your last call then call the helpdesk.
Hope this helps.
Device expertBrunoN
Show your appreciation!
Kudos”Kudos”
