nchaundy
Message 31 of 48
Re: New Premium Whole Home Wi-Fi Firmware released 20th April 2020 version SGAB203010
The e
additional discs only show on the web GUI not the iPhone App.
Yes I started with a 3 pack and then added 1 disc..
during the issues with connectivity I have done factory resets and re added discs a couple of times.. so perhaps that’s reason.
Tony0
Message 32 of 48
I've just bought the Premium Wholehome 3 pack. I installed it  yesterday  and immediately after installation updated the firmware. It's now 16 hours since the update. All discs are still flashing purple & I cannot connect via the Wholehome App. Fortunately, I can connect devices to the network.
Is this normal? How long will it take until the lights on the discs stop flashing and I am able to connect again?
Thank you
Sircoynie
Message 33 of 48
Can you connect via the web gui?
Tony0
Message 34 of 48
Yes, I've managed to log into the web user interface.
Under network status there's just a picture of a router, no information. Nothing under discs and nothing under devices.
Under the other menus, there is no information.
It's as though the Discs do not exist
Sircoynie
Message 35 of 48
Hmm.i think you may have the one option left.......cross your fingers and power cycle?
Tony0
Message 36 of 48
Thanks, I've done the power cycle and all is good.
Interestingly, the firmware is at the right version SGAB203010, but the app says last updated "never".
Still, good to have everything up and working, thanks 🙂
Sircoynie
Message 37 of 48
Great, don't worry about the app being wrong with the firmware version etc, it's just part of being the Beta testers for this product. 😉
oakserver
Message 38 of 48
This update has done wonders for the reliability of the system
My discs have been up for nearly 48 hours without needing a reboot and I have no reason to believe they shouldn't stay up. I seem to be getting less of the app saying it can't connect - although it does hang sometimes when you return to the app after a while. Killing the app and going back in usually sorts that out speedily though.
Still waiting for a bridge mode so that my existing router has full control of each device again (QOS) but in the mean time it is very usable.
Hopefully as the updates continue to improve reliability and introduce new features the product will gain some respect and improved reviews.
Lollingsgrad
Message 39 of 48
It's been a week since the updates; no network drops, no restarts required, I'm pretty sure our ISP had a lapse in service and the mesh didn't detonate like it used to do following the slightest blip. Massive thanks to the devs!
nchaundy
Message 40 of 48
Since the firmware update things have settled down..
I had a few issues after and disconnected Ethernet connection between sky box and one of discs in the lounge.. this seems to have stabilised things..
thing is now the disc in the lounge now nothing connects to it.. it shows on the App as ok but no devices are shown to connect or next to no data is shown on this disc..
