Sircoynie
Message 41 of 48
Re: New Premium Whole Home Wi-Fi Firmware released 20th April 2020 version SGAB203010
The Gui/Topology and connected devices is all over the place, I've put a post up proving it on another thread. Hopefully they will fix it soon.
GaryMo
Message 42 of 48
I’ve just noticed another firmware update has been released (SGAB204002) Has anybody tried it yet?
Im a little wary considering my discs have been rock solid since the last update a couple of weeks ago.
ZeusZeus
Message 43 of 48
I installed the Premium Wholehome 3 pack plus 1 extra disk a week ago and its been working fine.
This morning at 8am it started a firmware upgrade (primary 3 disks are flashing purple) but connectivity has been lost to the extra disk (red). Is this normal to lose the extra disk connectivity? When/how will this extra disk get its firmware upgrade?
Its now 10:15am and nothing has changed, how long should the firmware upgrade take?
Dan-O
BT Devices Expert
BT Devices Expert
Message 44 of 48
@ZeusZeus
You can try rebooting the add-on disc to make sure it has a good connection to proceed with the upgrade.
Discs will automatically sync their firmware upon connection so it's not an issue if a disc is missed from the initial firmware update.
Dan-O
ZeusZeus
Message 45 of 48
Hi Dan-0,
Many thanks for the response, I have restarted the extra disk but it has come back as disconnected (red) again.
How long should the firmware upgrade take? As all the other disks are still flashing purple and its now been going for at least 5 hours? and I guess started before I first saw it at 8am this morning.
Cheers
Zeus
Dan-O
BT Devices Expert
BT Devices Expert
Message 46 of 48
It sounds like it has timed out when starting the upgrade. Can you reboot the discs and retry the upgrade?
Dan-O
ZeusZeus
Message 47 of 48
Hi Dan-0,
Many thanks, 3 discs rebooted and now returned to blue.
Extra disc remained red, so applied factory reset and reconfigured and all good now.
Cheers
Zeus
Trappy
Message 48 of 48
My disks are stuck every time I try to upgrade I get the message there was a problem completing the firmware check. I have been trying the last month is there an issue 88D17C86-F99B-4550-AA4B-BF4362377630.jpeg
