FusionSnowball
Message 11 of 64
Re: New Whole Home Wi-Fi Firmware released 18-03-19 (version 1.02.08 build02)
Is anyone else having problem with this firmware update when playing video from a DNLA media server? Every few minutes it disconnects.
Everything else was working as normal with the new firmware. When I rearranged my network so I could connect to the media server without going over the Whole Home network, it started working again. I've now rolled back to the previous firmware version (glad that feature was added) and everything is back to normal.
mikew88
Message 12 of 64
Updated three days ago and so far all good. I have four discs and the main thing I’ve noticed is that the signal strength has  improved noticeably with the two furthest from the master...previously I was only getting good connections to both, now one is excellent and the other good but signal is -55 for one and -66 for the other (previously -68 and -73). Never had daisychaining and still don’t, all discs link back to the master, but who cares if it all works.
brummygit
Message 13 of 64
I've just arrived here after spending all day diagnosing a problem with my TV which has an ethernet connected disc about half a metre away. When I turned the TV (which was working fine yesterday) on to watch digital terrestrial TV this morning all I got was pixelation or no signal on my channels. Having checked (and replaced) cables, sockets and even swapped the TV (for an identical model) I discovered by accident that if the Whole Home Disc is turned off my TV works fine.
If I move the disc about twice the distance away I see an improvement but the TV reception still isn't perfect. It isn't practical to move my disc away from the TV long term. Further searching revealed the following in my Whole Home logs:
22.03.2019 01:55:55 [2 4 2] OWL-Firmware upgrade success from v1.02.06_build12 to v1.02.08_build02
So it seems that the update to v1.02.08_build02 last night has significantly changed the signal my discs are emitting to the point of interferring with my TV.
EDIT: A quick look on InSSIDer appears to show much stronger 5Ghz signals as I can see my other discs in a room where I would normally only see the offending disc which also shows a very strong 5Ghz signal.
protos55
Message 14 of 64
Just added a fourth extra disc, positioned about 150mm behind my tv. No problems so far, all looks good. TV, Amazon Fire, Chromecast and Now tv all connected to 5ghz , all within 200mm  of disc.
brummygit
Message 15 of 64
Yes, I have another disc a similar distance from a different TV which doesn't have any problems. But whatever changed in the firmware has increased interference that my other TV must be more  susceptible to
sfb
Message 16 of 64
Anyone having issues with version 1.02.08 build02
Hi, new here, although have come here a few times for answers over the last 6 months. I have a 6 disc system, and all was fine on the previous version v1.02.06 build12, but after updating to version 1.02.08 build02, 1 disc that use to be reliable, would prefer to connect to the first disc for a poor connection, rather than the usually 'Excellent' closest disk it usually daisy chains from.
Tried a power off and back on, it found the better disc ('Excellent'), but then reverrts back to the poor connction. Removed that disc and set up a spare, but the result was the same. Besides this I did notice the wifi seemed to become stronger with the discs that were connecting correctly. No matter how long its left for, it sooner or later finds the poor connection and holds onto it
For a few days I left it alone to settle, but no improvement, and today, I was finding discs dropping out, no longer able to reliably connect to the internet, phone for example would just cycle through 'connect - no internet - disconnect -connect....' Some items would no longer connect at all.
Tried a few complete power downs, restarts via app, but no improvement
Eventually this afternoon, I gave up and rolled back to version v1.02.06 build12 and immediately everything linked up correctly (Blue goods or excellents) , and everything that previous to the latest update, worked trouble free, connected back up and seems to be fine again
Anyone else had problems with the latest update? Ive turned auto-update for now
Stu
jrhop
Message 17 of 64
Re: Anyone having issues with version 1.02.08 build02
Yeah same here, new update they have better connection but prefer connecting to the primary over an excellent connection to a daisy chain one. I imagine that daisy chaining does impact speed having to go through one or more discs, but there must be a limit when it’s better than a poor connection back to the primary.
For me they all go back to the primary, but it’s not too bad, the furthest one is still a good -78 signal strength now I’ve moved it.
Takahashi
Message 18 of 64
How do you revert to previous version? Cannot see it in the app.
jrhop
Message 19 of 64
Follow the steps in this post https://community.bt.com/t5/BT-Devices/New-Whole-Home-Wi-Fi-Firmware-Early-adopter-release-18-02-19/...
Should only be used as a last resort.
Richard747
Message 20 of 64
I am now getting dropouts with 1.02.08 build02 and 'Incorrect password' messages that had disappeared with v1.02.06 build12. The firmware has been running for several days now and no improvement. All discs connected via Cat 6 cable.
