gazlad9
Message 1 of 6
No 5ghz on my smart hub.
I was changing the name of a device on my home hub yesterday when I noticed none of my devices were connected to the 5ghz network.so I thought o would try to separate the band's but when I done this my devices could not detect the 5ghz so I downloaded the Wi-Fi analyser app and this did not detect the 5ghz network either.Tried rebooting router, resetting to factory settings still no 5ghz could anyone shed some light on this, do I need a replacement router.
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: No 5ghz on my smart hub.
I expect the internal 5G radio card has failed, which others have reported on this forum. If you are still in a contract, then you should be able to get a free replacement, if not you would have to renew your contract.
If you are not in a contract, and do not want to be tied to a new 12 month contract,  you may be better purchasing you own third party router.
gazlad9
Message 3 of 6
I am still in contract could you suggest who I contact about this issue or a replacement router to buy that would just be as simple to set up.Do BT employees monitor these forums ?
Keith_Beddoe
Message 4 of 6
Just ring the broadband helpdesk, they should be able to arrange a replacement.
The moderators are BT Employees, but they are very busy, and it would be much quicker to call the helpdesk, or use Live Chat.
gazlad9
Message 5 of 6
Thanks will contact them when I get back later.👍
gazlad9
Message 6 of 6
Contacted by live chat they are sending replacement router out. 👍
