Message 1 of 5
No wifi
Hi there we are struggling to get wifi in our attic and out house, i have been looking at the bt wifi discs, can you tell me if there is much difference between the normal bt discs or the bt mini discs.  Cheers   will
4 REPLIES 4
Message 2 of 5
Re: No wifi
@willfc75
These would be a much better option. They generate their own wifi network, and also have two Ethernet ports.
https://shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
There is also a two hotspot version available. Look for
BT Mini Wi-Fi Home Hotspot 600 Multi Kit with wired AV600 Powerline and N150 Wi-Fi
Amazon sell it.
That would give you wifi in two separate places.
Message 3 of 5
Re: No wifi
Cheers again keith but i had some pluggins and they were not very good. As i would need to get wifi to two different areas of the house i was told that the bt discs would be great so i could get a three pack or otherwise i would need 2 packs of the ones you have shared with me. Would you know if there is much difference between the normal bt discs or the mini discs. Cheers again will
Message 4 of 5
Re: No wifi
The hotspot multi kit does two areas, you only need one set.
As for the discs, are you a BT Broadband customer?
I use these instead
Tenda Nova MW3.
https://www.tendacn.com/uk/product/mw3.html
Message 5 of 5
Re: No wifi
Cheers keith 👍
