msom
Message 1 of 5
Noise on landline phone socket
Please can someone help me?  My mothers upstairs phone is broken. It was part of a set of two handsets which were linked (wirelessly?)
I thought it would be sensible to just replace the upstairs one with a corded handset plugged into the phone socket upstairs but it is very hissing and noisy (sounds like a fax line but it becomes clear every now and then) .
Reading about this it seems to be linked to the Wi-fi (which Ive proved by solving the problem when router is switched off) I’ve read about a filter you can buy to solve this..... can you advise on what I need to get?
4 REPLIES 4
gg30340
Message 2 of 5
Re: Noise on landline phone socket
You need to get an ADSL Broadband Microfilter.
See link
http://bt.custhelp.com/app/answers/detail/a_id/635/~/why-do-i-need-adsl-filters-%28microfilters%29-a...
You may be able to get one locally or you can buy them online, It does not need to be a BT one.
msom
Message 3 of 5
Thank you so much.  The link says I need one on every socket.... the hub is on one bedroom and the phone line downstairs works well, it is just the pther bedroom, so shall I just put a filter on the bedroom socket?
imjolly
Message 4 of 5
do you have a filter on the hub socket and the current wireless phone socket or do you have a filter socket where the hub is connected  filtered socket will have 2 conenctions 1 for hub and 1 for phone
msom
Message 5 of 5
Im really not sure as I dont live near her.  The downstairs pohone socket and master socket wherre the router is are difficult to access.  Guess Ill spend a few pounds on one and see.  Many Thanks.  I will let you know how I get on (but I am not visiting again for a week or so)
