Message 1 of 2
Not another Smart Hub 2 Firmware update ! NAS can't be accessed !
This must be the fourth this year.
This is getting worse than Microsoft.
I suddenly discovered about an hour ago that I could not access my NAS, even though it was showing on Windows 10/Control panel/Network and Internet/Network sharing centre/View computers.
Despite re-boots and factory resets of the  NAS, and then the Desktop Windows 10 machine,  still no joy - but everything else seemed OK.
Then tried to log-in to the Smart Hub  2, only to find that not only my must recent password (Set 4/21) did unlock it but that the factory reset password didn't either.
So  I factory reset the Smart Hub and set-up new passwords.
And found that  the Firmware (In technical log section) was reporting that it had been updated @17:49 to version 0.27.06.04290-BT (From 0.26.04. 04227-BT, set in April this year).
Despite factory resetting still can't access the NAS though the sign-on window is easily accessible and the address reported is as previously.
Question 1. Are these "Firmware" updates legit ?
Question 2: If so, why so many this year ?
Question 3: How do I get the NAS access back ?
Any help appreciated.
N
1 REPLY 1
Message 2 of 2
Re: Not another Smart Hub 2 Firmware update ! NAS can't be accessed !
1  yes
2   normally for updates due to fixes required often highlighted by customers posting here on the forum
3  have you turned off smart setup after your factory reset
