Message 1 of 6
Old Smarthub 6
My BT FTTC is due to go "live" on Monday next.
I am, until then, with Plusnet. I have been using a Smarthub 6 for my Plusnet connection by entering my PN details which works fine.
I have received an e-mail from BT advising that a new Smarthub has been sent out, as expected. However, I'd rather continue using the existing Smarthub rather than reconnect all the wifi devices to a new one.
In the e-mail it stated that an old Smarthub cannot be used, it will not work and the new one must be used.
Is this correct and if not how would I set up the old Smarthub to connect to the new BT FTTC?
Thnks in advance.
5 REPLIES 5
Message 2 of 6
Re: Old Smarthub 6
You just need to change the username to bthomehub@btbroadband.com
Message 3 of 6
Re: Old Smarthub 6
Thanks for that. Is there a need for any sort of password too?
For Plusnet I have to enter my username and access pasword.
Message 4 of 6
Re: Old Smarthub 6
No password needed for BT
Everything is generic as authentication is against phone number.
Message 5 of 6
Re: Old Smarthub 6
Thanks again.
Presumably this, from their e-mail, is incorrect? "If you're already using a BT Home Hub or another broadband router, it won't work with your new service, so you'll need to unplug it and use the new kit we're sending you instead."
I would have thought customers buy and use third party routers to use with BT fibre without any problems?
Message 6 of 6
Re: Old Smarthub 6
many adsl routers are not capable to vdsl hence 'won't work' but any third part modem/router will work ok with BT FTTC
