RobertJones
Message 1 of 2
One of pair of Mini Connectors not working, no lights even after pressing button or restarting many,
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: One of pair of Mini Connectors not working, no lights even after pressing button or restarting m
Hi @RobertJones Welcome to the forum and sorry you are having a fault with your Mini connectors.
Check out the Help Page  and the user guide is available there also and hope this helps you get this fixed.
cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
