Message 11 of 13
Re: Only one ethernet port works on BT mini connector
Hi @pddco
Yes, the router and the connector's been reset and I've tried the IP address 'trick' that @TimCurtis  suggested - still no joy. I'm starting to think @licquorice is right about the 2nd port being there for show.
It would be interesting to know if anyone on here has ever had two PC's working off a single connector.
I'm going to see what happens if I plug in another connector for the 2nd PC.
Message 12 of 13
@Arthur_Brayne
Which PC didn't connect? Was it the one where you set the IP address?
If none of this works then the simple solution is a 5-port switch - preferably TP-Link.
Message 13 of 13
@TimCurtis
Apologies for the delayed reply, I've been abroad for the past week. I can't remember now which one didn't connect but, as I've got a spare switch I've tried that and both PC's now connect.
