sam1111
Message 1 of 2
PAIRING with Mobile: BT Baby Monitor 6000
I have a problem with pairing the monitor with my mobile phone.
I followed the instruction on the bt smart app.
My camera Item code: 088306.
It can't detect the camera. Suggested to go wifi and connect to Camera HD-XXXX.  There is no such wifi available.
If there is a manual set up details, I do not have it.
Can you help me to connect the cam to my mobile app, please?
Kind regards.
1 REPLY 1
MJay
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: PAIRING with Mobile: BT Baby Monitor 6000
Hi Sam1111,
The item code 088306 is for a BT VBM6000. Unfortunately This model does not work with the BT Smart App.
The model you need if you want to use the BT Smart App is the BT Smart Baby Monitor.
Hope this helps?
Martin.
