gibbs1001
Message 1 of 3
Port forwarding - BT WHole home Wifi
Is this possible to setup?
2 REPLIES 2
NeilO
Moderator
Moderator
Message 2 of 3
Re: Port forwarding - BT WHole home Wifi
@gibbs1001 As far as I am aware you only need to set up the port forwarding on your router but I'm sure @Dan-O would be able to clarify this for you when he's next in the community.
BrunoN
BT Devices Expert
BT Devices Expert
Message 3 of 3
NeilO is correct. No port forwarding in Whole Home; it's a bridge. You need to do this in your router.
Hope this helps.
