A_ph
Message 1 of 8
Power Cut and Smart Hub 2
Why should a power cut mean that when power is restored my Smart Hub 2 is now faulty? After reporting it to BT I’m having to wait 4 days for a replacement. In this day and age I question both the product reliability and the fact that deliveries can’t  happen the next day?
From a frustrated person who works from home and who has 3 teenagers who use Wi-fi a lot!
7 REPLIES 7
Message 2 of 8
Re: Power Cut and Smart Hub 2
@A_ph
How do you know its faulty, is it totally dead without any lights on the front? If not, then it could just be a line or network fault.
If you need to get back online quickly, then you can get a third party router locally for about £40, and it can always be used in future as a spare.
Message 3 of 8
@A_ph  have you checked to see if you have a dial tone on your landline?
A_ph
Message 4 of 8
Went through checks with BT last night, there’s a permanent orange light. Did a reset and it was still orange. They said it was faulty so sending a new one out.
Thanks for info about 3rd party router, will look into it.
A_ph
Message 5 of 8
Yep dial tone on land line working normally
Message 6 of 8
It could be a problem in the cabinet, as the backup batteries would have run out and not recovered, or the power supply has tripped out. I would be very surprised if its the home hub, as that should not be upset by a power loss.
If you want to try a third party router, and you have an Argos store nearby, then look at item 5728882. Its easy to return if it does not help.
Message 7 of 8
sorry was that a factory reset by pressing the recessed button on back and holding 20/30 secs until lights flash?
A_ph
Message 8 of 8
No I was asked to turn hub off, unplug it from power, wait 2 mins then reconnect and wait
