saustin77
Newbie
Message 1 of 2
Power up BS message on BT everyday phone
I purchased a BT everyday phone a couple of days ago. I've followed the instructions and had it plugged in charging, however the phone still displays the  'Power up BS' message. I've made sure the phone is in contact and it lights up  orange when it makes contact. Are there any ideas of what is wrong?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Power up BS message on BT everyday phone
Hi @saustin77  welcome to the forum and thanks for posting. Sorry that you are having a problem with your new Everyday Phone. I'm not sure what is wrong here so you would be best to speak with the product experts on the Helpdesk and I'm sure they will be able to help you with this. They are now open today but you can call Mon - Fri 9am to 5.30pm or Sat 9am to 2pm or you can drop them an email. Post back and let us know how you get on.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
