Dan-O
BT Devices Expert
BT Devices Expert
Message 11 of 17
Re: Premium Whole Home WiFi firmcheck check failing
@Marcel
Are you using the iOS app or Android? Did you use the Beta programme button in the iOS app at all?
Dan-O
Marcel
Message 12 of 17
@Dan-O  I am using the IOS app. I have tested new versions through TestFlight before if that's what you mean ?
Marcel
Dan-O
BT Devices Expert
BT Devices Expert
Message 13 of 17
Hi @Marcel
Are you seeing the error "There was a problem checking for firmware updates" or are you just seeing no update available?
Have you tried switching the primary disc with another disc to see if this resolves the issue?
Dan-O
Marcel
Message 14 of 17
Hi @Dan-O
I get the message that there is a problem checking for firmware updates. When you say swapping the primary disc, do you mean physically connecting a different disc to the uplink ?
Marcel
Dan-O
BT Devices Expert
BT Devices Expert
Message 15 of 17
Hi @Marcel
Yes - there was an issue with the iOS app 3.10.26 which could have incorrectly changed the update details. You could perform a reset to restore this or if you physically change your Ethernet connected disc with another, it will cause a re-sync of details but you won't need to set up everything again.
Dan-O
Sircoynie
Message 16 of 17
What is your test model for this product? Feels like we as customers are your QA?
What an awful experience!
Marcel
Message 17 of 17
@Dan-O
But this wouldn't explain why the web GUI also fails after 7 days ?
 I am running iOS app 3.10.28
Marcel
